Ok.. lemme help out here. Because what's going on isn't going to be second nature to a new guy with the tuner.
HPT validates that the operating software version (OSID) on the pcm matches a valid entry with one that was used on the year/model aka vin matched. There's a GM website (can find at HPT) that you can check if you can get the OSID off the pcm.
DHP does not validate year/OSID/vin at all and let's you do anything you want.
ZZP.. one of the big fails by them in my eyes is that they will write a different year OSID with DHP to a pcm. Say you have a 2001 GTP, they might write 1999 software to your pcm. Well the OSID is for a 99 and your vin is an 01...MISMATCH and HPT see's that and says no go. ZZFail pooched ya again.
If you need a stock bin, I have many in a repository over at a site I run. (Nick...when we getting that up and running here?)
BonnevillePRO.com • View forum - Tuning
Pull down a bin for your year/model and then load that will a full write to the pcm. Once it's done, change the vin number from the flash menu and it should be all set for you to be able to tune. Only problem you might encounter is since you don't have the offending OSID year licensed you might not be able to overwrite. HPT also requires that whatever is on the pcm is unlocked as well as what you are trying to write is also unlocked. It's kinda a pain, but if you license an 01 then 01 should be the pcm you use.
That's the part where I use a DHP to program a say 99 pcm to an 01 software so that my HPT will see and be happy that I'm writing an 01 bin to an exiisting 01 OSID pcm.
Does that make sense?
Bill/Chris were probably suggesting you get a reflash from a dealer of your car's stock programming.
