Vibration and noise on takeoff
I had the hood open and watching the engine while my wife held the brake on and applied the gas,,,,the engine does move not an extreme amount but it does move quite abit
more then a 2 inch bounce?
also when its in gear, d or r, do you notice if the engine is twisting at all? you can tell by watching the dog bones, they should be straight out to the engine, if they are pulled one way or the other the lower mounts are dead.
my engine was twisting like crazy, it never vibrated clunked even, but the engine did move a lot.
my first shot mount. well whats left of it.
the last mount i changed. oil leaks kill the mount fast. why the new one is coated with filler. i also drilled, drained, and filled this and the trans mount. filled the middle section and the bottom of it. as well as coated the top to try to keep my oil leaks from eating the rubber up.
