footballplaya3k
Are you using a canned tune? A canned tune, unless otherwise specifically ordered, would likely be set for the restriction imposed by a box or fenderwell, since the "open cone" movement has only recently gained popularity among GP mod-ers -- it's assumed that you would not use open cone.
Did you re-tune for the intake change? What AFR were you running WOT? If you do not know this because you do not have a wideband gauge, then you have absolutely no valid argument and no reason to being "ambient air temps" into this before mentioning AFR. AFR is GOD.
My best guess would be that your car was tuned for a cai or fenderwell by your tune vendor, so when you stuck an open cone on it, you got too much air in and ran too lean. So when you stuck a box on, it's air restriction "fixed" your wrong tune by letting you scoot the AFR a tad richer, allowing the engine to make more power.
Edit: I want to make sure I'm getting the right idea across: Until your build is extreme, I do not believe that either intake is a superior performer by its own merits. Rather, it is the tune, which dictates the AFR, that will decide what kind of power/power-failure [read: knock ->timing retard] you make.
Well seeing how your argument completely disagrees with everyone else in this thread I would say you're wrong. Bio, blue and Matt have all said my intake is not a restriction at my point in modding. So you are saying they are all wrong as well?
I have a canned tune that was ordered while I had the HAI and I told Will to tune it for the HAI, so if anything I would be even faster with a better tune for my CAI.
I do not have a wideband, wideband tune or tuner so I do not know my AFR, I only know how much timing im running because my buddy tuned out my KR and gave me a MAF tune. He just got the tuner not too long before he did this for me.
Overall I know a decent bit of ppl running WizAired intake on their fairly decent modded cars. One of which has an XPZ, stage 4 ZZP heads, 3.0 Gen 3 with OD balancer (so basically a 2.8), 20* timing with no KR setup and he says he will never switch to a HAI. I would be willing to live with his setup, he seems to be doing "okay" with his WizAired intake.
