Dave, those aluminum mounts are weak in the first place. I snapped mine a long time ago and it got worse as time went on. I contacted Ed and had asked him about it. The polished dogbones from 3800 are a little different from the stock dogbones. Most people tend to over tighten them and the aluminum mount bends in as it gets tighter. with the vibrations in the engine, it can cause them to snap.
The best advice I can give you is what Ed told me, make sure you tighten them, but not overly tight. Also, if you can get a washer to act as a spacer for those to go between the bushing and the mount, it'll help a little also.
Hopefully you can get a replacement in somewhat quick and get it all put together. Hope this helps.
David man that sucks bad dude good luck with getting the parts man. If I had the bracket I'd have it to you asap if i had one in my hands dude good luck.
that part only looks to be $22 for one side and $52 for the other, from one of the online GM parts retailers. Not sure which one is in the picture.
I know and if all goes well I should be able to if he can't just in case which one is it?
Thanks for everyone's help. Replacement part is being FED EXed to me. I should be up and running by the weekend. :th_dancingpepper:
Yes I used the Gm-Car-Parts site
Maybe this time...polish this weak piece of pop-tin aluminum instead of plating it.
:th_winking::th_thumbsup-wink:
~F~
