vaccum lines
08 gp lvr
I tried go do a search of the vacum line diagram for 08 gp n/a with no luck. I'm looking for a layout of my vacum lines because that's all that's left to troubleshoot, needless to say about my new issue bbq smell from under the hood. I know of the ones along the air intake but that's about it. I just don't know were else to look. Thanks a lot
This?
Thanks alot, Ive read that I wanted to find a vacuum leak was to spray brake cleaner or other substance slowly and listen for the idle difference. Ive always done my own work but as far as vac. lines are concerned, ive never had a car worthy enough to track it down. The reason I say a vacuum leak is because when i turn the blower on, the rpms drop to under 500. if it idles for more than 10 minutes when hot, idling jumps abit, transmission shifting is late sometimes and doesnt shift normally. I understand after 99 they removed the tranny regulator responsible for shifting and my neighbor was telling that my lines are responsible for this issue.
Blow the smoke on the engine and where you see it getting Sucked in is your vac leak.
Sent from A Galaxy Far Far Away.....
