    TIPS:
used set of lim gaskets
SgtMarshal
Active member
I'm looking for a used set of lower intake manifold gaskets. I don't care if they seal, I just need them in good shape so I can use to port a lower intake manifold. I can do like 10 bucks shipped, unless they don't fit in a small flat rate envelope.
I'm sure I've got a set laying around still if no one else does. You want the stock ones or the updated alum. ones?
If I remember right if you don't have ported heads then don't port the lim. It causes turbulence because the lim is bigger than the heads after porting. But I might be wrong about it.
Not sure why you'd need a used set... You just use the Dykem and scribe your gaskets onto the lim, remove gasket and port match away... Lol, did mine to my StageII heads and LIM
just know too, there's are no gains from this, only smooth flow ; )
I have a set if you are desperate ; )
let me know...
I ordered a new set of gaskets, so I'm good. that is good info, I didn't realize there were no gains except smoother flow. at the same time I will be installing a ported supercharger, so that should help.
