urgent need help misfire
acdelco's, not sure exact ones, assuming stock. the plug wires are aftermarket too. the guy claimed to have had replaced them 3k ago...
wires are "belden edge" 7mm wires. i compared resitance between the wires on my gt and the gtp, there about the same resistance. not sure about plugs. its pouring i just got soaked checkin wires
Bill lives in Enfield CT, im sure he could diagnose it for you if you get it to him, i see you are from mass. Sounds like either the o2 sensor is out of range at wot or a bad fuel injector. is the car completely stock?
crappy droid pic
41-101 are iridiums. Shouldn't be a problem. Unless you pull that cylinder and see something directly shorting the tab to the center. I'v ehad that happen on a couple ATVs in the past.
i also forgot to metion it only does it when im heavy on the throttle but when i was light just gettin up to speed i did not notice a missfire. i drove for an hour on the highway and the last like 2 miles from home i layed on it and thats when it misfired/
so i did a compression test. cylinder 6 and 3 both show 165 psi. what gives? im completely cluelesss as to where else to look
so would driving it right now be bad? im dying to put it on the road its killin me lookin at it. and i have a few people interested in the gt
