upgrade
The only thing I can think of is that since exhaust work was done, and I'm assuming you mean it's sluggish, the o2 sensors may be the problem. They could have been damaged or disconnected. Any codes?
First thought would be since you essentially deleted the CAT (if I am reading you right) the PCM is putting your car into limp mode. But it SHOULD be throwing a P0420 code...
