UPDATE, pg.2!!! Drivers Door Adjustment? Hinge?
Re: Drivers Door Adjustment? Hinge?
Nope I haven't yet, i need this fixed but i've been busy at work. As soon as i figure out something, i'll post it up. As far as I can tell, the hinges aren't rebuildable...
I will look into this myself. My passenger side door is rubbing on the bottom corner. Has anybody came up with anything on this yet?
UPDATE!
Actully I did today, nothing great but it works and doesn't rub anymore. The real and best fix would me to get new hinges since there not rebuildable. I'll probably end up doing this, for now though, my current fix is working excellent. And I didn't have to remove the front fender.
All I did. I took my cherry picker, used a nylon strap, rolled down my window, tied the strap on my door frame and snugged it up. Loosened (not remove) the two lower bolts for the lower hinge on the door side. Applied very minimal pressure on the cherry picker, I inserted a 1/16" fender shim (smallest on hand) on the lower most bolt and tightened her down. After checking and making sure the door had perfect fender clearence, I re-adjusting the stricker on the door post, everything fits, lines up, and works great!
I have a whole bunch of fender shims from various body projects in the past so it didn't cost me nothing but a little time. Fender shims are dirt cheap though, a few bucks at OReillys will buy you a whole box full of them with various sizes. And there handy to have when aligning body panels, especially on an old school car. The cherry picker you don't need either, but since I have one handy, I could do it by myself with ease. I'd recommend having a hand there when you start placing in shims to lift up the door for you.
Hope this helps out someone...
My '00 GP GT (sedan) driver door was sagging so bad that whenever I would open it, it would "pop" and scratch the fender/door seam. After awhile I got annoyed and the paint was coming off so I took it to the stealer, I mean dealer, and they said my door moved forward (comparing it to the passenger door) most likely from a strong wind when it was open all the way or something similiar. The dealer only charged me $50 to re-adjust the door, touch up the paint, and actually pull out the fender a bit. Yes, it got so bad my fender was bent a little. Not bad, I took it to the body shop, not the mechanical service shop here in SE Michigan. The manager said if I needed hinges it would have cost about $200 a hinge but I was no where near needing new hinges he said. I usually am a DIY'er, like you all, but this was out of my patience, and time allowance. Hope this gives you another idea...
