offroadfury6
you modify the housing so it sits at the right distance.
makes better sense...thank you...I may just leave that alone then.
the bulb housing.
not your headlight housings....
my issue with my HID is that they are not bright enough, I bought them from DDMtuning, they are the same brightness as my slyvania ultras...
...just in case a 97-03 owner reads the previous statement and just wants to go down and get Silverstar Ultra bulbs, don't - here's why:
For the stock 2003 housings, the Silverstar Ultras do not even come close to the same output compared to my DDM HIDs. The DDM tuning HIDs are almost too bright, and they light up everything. Everyonce in a while I'll get flashed from people that think my brights are on. ....my buddy says they are too bright... I absolutely love them and will recommend them to anyone.
I wish I had the same experience with my 06. I think moddifying the bulb is needed in my case![]()
To fit the 9006 bulb in for your low beam?
no, they fit...I mean modify the bulb...See the very first page of this thread...
With my DDM kit, there is no need to buy the error eliminator. The DDM kit leaves the passenger side OEM bulb unplugged because ther DDM harness only connects to one bulb connection. For some reason, the brights indicator on my dash and HUD is constantly on. It's dimmer when the brights are not actually on, but it's still there.
I plugged in a stock bulb to see what would happen and it fixed the brights indicator on the HUD and dash. Since I have the 9004 bulb plugged into the stock harness, I now have an underhood light.![]()
eh... ok.... I can also break off the bulb and tuck it under the housing in the bumper... i just don't care right now.
