Two Issues - Headlight Aim and CD Player
shoema
I have an '03 GP SE. Any advice on these two issues is greatly appreciated:
-Headlight Aim: I need to know how to adjust one of my headlights which is aiming up higher than the other light. I need to know which adjustment to use and what type of screw is needed to make the adjustment.
-CD Player: Does not work. I get an Error code (can't remember the code name right now :confused: ) but it will just spit out every CD that I put in it. Also, the LCD light is out on the player - I cannot see anything, only when sun is shining on it. Any way to fix this?
Thanks!!
I had the same exact issues with my cd player. I ended up sending it to a company that refurbishes stock radios. They sent the radio back saying there was a problem with the cd player mechanism and they replaced it. That fixed the "spitting out the cd issue". The LCD light was just a bulb that was burnt out. You can probably replace the bulb for the LCD but not sure if there is anything you can do about the cd player spitting out cds.
