NebTurboST5
higher 11's but on e85 you shouldnt have too much trouble making over 350+ whp. it will be the L36 bottom end that holds you back i was always scared to turn mine up past 13psi. next thing it will need is some help breathing.
Just use ls7 lifters. Oer lifters only work well if you have adjustable rockers. No point in upgrading from stock rockers unless you are spending the big bucks on adjistables. Just run stock, and measure your pushrod length.
I would switch to titanium retainers with 150# springs. I don't really like the Manley retainers that intense sells. Comp cams makes a better retainer.
You have 130# springs though, right?
Yup! I bought a st5 cam with 150# springs going on the heads, and a double timing chain. GTPpower where can I get the comp cams retainers?? Zzp doesnt sell the titaniums.
yeah actually the crow 125# shimmed to 130# should i get 150# pac springs?
What rpm does your power start to drop off?
about 5900 last time i was on the dyno.
Hmmmm. Is your turbo running out of steam?
500 horse?! Im still looking at things to buy but if I need something I need it haha. Im going to order the retainers and lifters today then I will be looking into anything else I will need
