turbo oil lines
SgtMarshal
Active member
when I hook up the oil lines to my oil level sensor and oil sending unit, will the universal oil line kits on ebay work, or will I need adapters for the different threads and/or sizes?
find the correct AN size and yes, dammit private
-4 and -10 because I know you will 1/4 and 5/8
yes but id suggest against it, ive never been happy with ebay critical components. even in the picture you can see flaws in the outer braid.
that and saving $ never really saves you $ is damn near a law stronger than gravity.
keep in mind that if that line fails your buying a new turbo and engine.
we are using a pre crimped 48" or 52 ish inch premade aeroquip or earls line, one end with the 90* -4 AN end and the other a straight -4an.
actually it may be 60"...dunno. believe it or not, if you have a mig welder, mig wire is actually pretty good at helping you figure you a graceful line path and length since teflon line has a curve memory like mig wire
then you use a 1/4" npt to -4 fitting (straight or 90, dep on fitment) at the filter neck....i finally decided not to chance it and i just deleted the oem OP switch on the TR, i wont be getting rid of our T though as i plan on running an AEM unit at some point.
at the turbo we have the straight end with a 90* 1/8th npt to -4 fitting threaded into our 1/8" m/f npt restrictor.
