tune up for long trip
you need to fill your tank, set the trip, run the gas down to where you would fill up, then fill the tank again, take the # of gallons you just put in and divide the miles driven, = mpg
i used my gps to track distance and divided the miles by the amount of fuel it took to top it off, it came out within 2 mpgs of my trip computer thing, this might be because i am running 235/55/17 tires instead of the 225/55/17 stock (i think thats right)
You should have a code for that.
you wont get a code until the cat overheats. with 110k on a stock dp you probably have a cat thats getting pretty clogged. id get it replaced before you get any bad issues.
if you were doing 60-70mph the whole trip i bet youd see some better gas mileage, but 22 highway is kinda low.
