Trying to locate the grind.
Bluemagic
Ok lately I have been experiencing a sort of grinding noise when driving slowly. When I removed my wheels and turned the wheels as if they were in motion both fronts moved kinda hard. It's like something was holding the wheels and it was kinda difficult to turn the wheels. Also while investigating I saw that my drivers side axle boot was torn and had no grease In it smh. Could this be the issue? Thanks guy's
Sent from my HTC One using Tapatalk 2
A hub will exhibit noises at speed usually. Can go away when you turn one way or the other. Brakes will often be when you aren't pushing on them.... CV usually clicks and doesn't grind.
Rotors are shot. So I'm thinking the brakes are catching the rotors while driving.
Like bad, I changed the back but money has been tight so haven't got around to the front. I'll grab a pic in a few
Crappy rotors
