trunk/reverse lights...
popnajera
went through and saw a few threads.. replaced fuse 27 worked for ohhh a day.. then pushed my button and nothing again, took fuse out it was blown, tossed another in and now they just blow... any clues as to where i should start because im at a loss i thought i had it fixed by just replacing the fuse i pulled the tail lights off looked at everything no wires touching anything like that. any help would be appreciated :(
there must be a wire rubbing somewheres between the back of the car and the fuse block to cause it to short and blow the fuse. good luck finding it
by chance anyone have an idea where the wires(what loom) they are in... so i dont have to rip them all apart :/
Start at the tails and work your way back. I'd also double check with a multimeter that the circuit is shorted to ground. That way you ensure you are chasing the correct issue.
