02NavyBlue
You thought I was talking about end links? Lol no way man. I would cut links if they gave me any trouble.
for separating stubborn lbj from the knuckle I loop a chain around the c/a near the bj. Then slide a long pry bar through the chain and wedge the tip under the subframe. I have someone push down on the prybar while I give the side of the knuckle taper a rap with the air hammer.
No it should come with everything you need
Sent from BFE
Only note i have the actually bushing upside down. Notice how one side has a like raised circular bit? That goes into the bar same for on the LCA, hope i explained that right
Sent from BFE
the bushing go on top and bottom of the sway bar and the lca mount. see my pic up there.
not when you live in the rust belt.Holy **** thats more work than you need. Just get a BFH hit the lower part of the knuckle 1 or 2 times and the balljoint will drop then use a pry bar on the C/A to get the balljoint out of the knuckle
