Z34Phoenix
Florida Tuner
Not sure if this will work for the blowers but it works on my DOHC. on my upper intake i got tired of tearing gaskets when i need to get at the rear bank to do plugs or get at the back of the engine... so, i got two gaskets. one ends up getting stuck to the upper intake and the other gets stuck to the lower. the two gaskets seal tight to each other but will not stick either... so i can take it off and put back on when ever.
this might work for the blowers too or for people running IC's use an extra SC gasket and maybe they will separate. only issue i can see is the coolant that flows thru... they may stick there... anyone try this or want to try this?
