TheOtherNick
The mod from over yonder
Oh yeah I forgot about their new service bulletin updating all prior cars to 6. Stick to 3 and be happy.
I would not put dex VI in a trans designed for III, gm switched to VI in the 06-08 range.
The VI will work in older Tans's but not vise versa. The kicker is the cost of the VI it costs over double the amount of the III maybe close to three times the cost...
OP- Before I forget -once you drop the pan and remove the filter, be sure the rubber o-ring on the end of the filter where it goes into the trans. is removed as well. They often get stuck in the trans and you have to use a pick or something to get it out.
I used Dex III on both of my pan drops. I was e-mailing Dave at TEP a time before and he mentioned that DexVI is more a thinner synthetic and if the trans hasn't been maintained the best it could have, then it could cause it more problems thus stick to DexIII and be safe.
Maybe so..but given the condition of my tranny at the time, he recommended sticking with what I had to avoid any further complications.
IMO, better safe than sorry. If it works and ain't broke, don't fix it by upgrading fluids.
BUT I'm not going against what your saying, so yeah. Just throwing what I was told in there.
If switching to Dexron VI is going to ruin your tranny, you have other issues. I can't speak for Dave or what exactly he said. It is true that Dexron VI is a thinner fluid and I believe most are synthetic. But from everything I have read and seen, it is a great fluid and should be used in most transmissions as a replacement.
Our clutch meterial was not desined to be used with the thinner fluid, and when you add more power it will want to slip more, and with the thinner fluid it will just make it worse. Same as if you where using a truck to tow a trailer stick with III if thats what its made for.
