Blazeracer
I've had my 2000 GTP since new. Bought it with 6 miles and it now has 144k on the clock. Never had any major issues with it until yesterday. Drove it to work in morning, got her up to almost 90 on the freeway just tooling along down the road. Everything was just fine. I came out to go home, started it up, put it in reverse.. NOTHING!! No grinding noise, no thump, nothing. The car won't even attempt to move.
Checked the fluid and it's full. No leaks. Check the linkage and the cable is moving the shift lever on the tranny. Shift inicator is working, back up lights come on, but the car won't move. Hooked up a rope and towed it home with my truck, so it goes into neutral just fine. Tried putting it in gear going down the road and still nothing.
There was absolutely no indication at all that anything was wrong on my drive in yesterday morning. Car ran great, pulled hard and shifted strong as usual. I'm thinking it's got to be an electrical fluid control component of some sort. Unplugged the two wire connectors and plugged them back in but that didn't do anything either.
Any ideas?? I don't think it needs rebuilt cause it has always worked so well. Something quit. Is there a fuse or relay for the transmission contol?
