timboku
Alright been working on this project on and off for a little bit. I will try to make it short to see if anyone had input and can help. I sold my GXP so need my gtp up and running so I dont go through GP withdrawal
I installed a TEP stage 2 VB, Dynotech Input Shaft, and 7/8ths 2.93 chain in to a 97 65eHD that is in my 2002 GTP. The trans has about 20k on a rebuild, Torque converter has less than 5k on it, Transgo Shift kit, and a Explorer trans cooler installed. The trans worked and shifted perfectly before I installed all this and the fluid was pink when drained before rebuild. All parts are Brand New.
Problem:
When put in D you need to rev it to 2500 RPM to get it to move, if you put in in 1, you get more power but still seems to slip. When you get up to about 20mph, it shifts and functions normally, Reverse works good. When put in drive, you never really feel it go into drive...the motor doesn't move like it does when put in Reverse. Also, the temps climb to 210 degrees after driving it for like 10 mins.
I have had it apart numerous times to try to fix this.
What I have done so far: With recommendations from Dave from TEP who has been great.
-Re-torqued VB and channel plate,
-Checked that check balls are in correct place (the first time one was missing my bad)
-Pulled accumulator to make sure shift kit was installed correctly
-Checked Forward band, it is intact and looks normal
-Checked wire harness
-Installed new AFL valve into channel plate
- Re-torqued again VB again 3 times
- Cleared pcm and left battery disconnected to clear TAPS
-Hooked up Aeroforce and trans was starting in 2nd gear and never shifted originally after 2nd time dropping cradle. (i think a messed check ball in the channel plate caused this but it functions normally now and starts in 1st as it is supposed to)
It seems to get better a little as it drives and learns, but something is not right as it feels like the trans does not catch.
Questions I have:
- In researching the 97 to 00 VB is different from a 01 to 02. as well as the check balls in the channel plate is different for the cooling check ball. It looks like i was sent a 02 VB as that is what Dave from TEP said it was. Is there any issues installing a 02 VB in a 97 trans with a 97 Channel plate? Dave said it does not matter?
- Am I missing something, I followed the instructions in the Trans Manual to the T,
- Gonna drop cradle again and pull side cover off. Was thinking of installing my old VB in to see if that changes anything??
Any input would be awesome.
Thanks in advance.
Problem:
Questions I have:
Thanks in advance.
