stealthee
Why would I route the lines to the drivers side when the factory lines are on the passenger side?
Also, I wanted the lines going to the factory lines to be as short as possible. The longer you make them the less effecient the cooler is. I also wanted the cooler mounted to where it would get direct airflow. The only way to get that put me in a position that limited basically everything.
I was on limited time as well. In order to properly mount the cooler I was going to have to remove the radiator, fans, and hoses.
