Traction control light always off?
mok4200
Hey guys, dont 't know if this is a common problem with grand prixs or not but my "TRAC OFF" light is always on, even if i press the traction control button, nothing happens, anyone have a clue on what may be causing this??
Is your ABS light on as well? Usually this is an indication of a dirty/broken conenction at the wheel speed sensor or a bad wheel bearing, usually in the front.
I have the same problem with my 2003 GP-SE. Did anyone ever solve this? The Trac Off light is ON all the time and the trac button does nothing. My ABS and Engine lights are both off. I thought the passengers side hub was the problem so I replaced it. No change. I plugged a new wheel hub in on the drivers side (but didn't have a time to replace it yet). No change. I inspected the wires and added dilectric grease to the connectors.
