TPMS...I know,I know.
MyteeMyk
So I searched this forum to no avail. Had a nail in FR tire, took to Les Schwab.They said it was no through and through but added a lil air to 35lbs. All tires were at 28-29 prior.So now the TPMS showed 28FR/29FL and 29 RL/35RR. So I stopped today to put air in fronts and went to 28FR/29FL-35RL/41RR.
So it's backwards. Guess I should just ask,is there a easy way to flop it to read correct (front is front-back is back) or do the sensors need reprogrammed to the computer.
Thanks,I'll take a look at the manual 2nyt.Was thinking if the 08 used a transmitter signal and the tires were rotated, the TPMS just wasn't reset.Gonna be get'n new wheels/tires soon anyway so myt just leave it till then.Least I know which tire(s) are being displayed wrong.Thanks again.
I am reollecting off the top of my head, but to reset the 08 you need to put the key in the ignition, turn it to on, but do not start, hold the lock and unlock buttons on the key fob until you hear a honk, then start letting air out of the drivers front tire. Once it honks you can move to the drivers rear and let air out until it honks. Move on to the passenger rear and repeat, and passenger front and repeat. I beleive once its set it will do a double honk.
Please verify that before you do it, like I said, I am going on memory,
