touble programming keyless entry remote, 04 grand prix gt
billk82
i just bought a 2004 grand prix gt and the keyless remote does not work. i tried replacing the battery and nothing. ni cleaned the contacts and it still didnt work. the solder on the circut board that holds the battery clip in place looks fine. i have done some research on line and i found a site that said
(1) REMOVE KEY FROM IGNITION SWITCH.
(2) REMOVE THE 'MALL PGM FUSE' FROM THE [FONT=inherit !important][FONT=inherit !important]FUSE [/FONT][FONT=inherit !important]BOX[/FONT][/FONT].
(3) CLOSE ALL THE DOORS.
(4) TURN THE IGNITION [FONT=inherit !important][FONT=inherit !important]SWITCH[/FONT][/FONT] TO THE 'ACC' POSTION.
(5) WITHIN 1 SECOND TURN THE IGNITION SWITCH BACK TO 'OFF' THEN BACK TO 'ACC'.
(6) OPEN AND CLOSE THE DRIVERS DOOR A CHIME WILL SOUND INDICATING PROGRAMMING MODE ACTIVATED.
(7) TO PROGRAM THE REMOTE PROCEED AS FOLLOWS:
a) PRESS AND HOLD REMOTE [FONT=inherit !important][FONT=inherit !important]TRANSMITTER[/FONT][/FONT] LOCK AND UNLOCK BUTTONS UNTILL A CHIME SOUNDS TWICE, APX 14 SECONDS.
b) REPEAT ABOVE PROCEDURE FOR EACH REMOTE TRANSMITTER.
(8) REMOVE KEY FROM IGNITION SWITCH.
(9) REFIT 'MALL PGM' FUSE.
NOTE: EXISTING REMOTE TRANSMITTER MEMORY POSITIONS WILL BE OVERWRITTEN.
(10) OBTAIN AND REPROGRAM ALL REMOTE TRANSMITTERS.
NOTE: A MAXIMUM OF 4 REMOTE TRANSMITTERS CAN BE PROGRAMMED.
***ADDITIONAL FEEDBACK SETTINGS CAN BE SET TO RESPOND TO THE REMOTE TRANSMITTERS.
the only problem is i cant find the MALL PGM fuse. i looked in the fuse box on the side of the dash and under the hood. i would really like to do it my self and not have to go to the dealer ship.
You can't find the fuse because you don't have one.
2004+ keyless entry remotes need to be programmed by a dealer with a tech II device.
so it has to go to the dealer. i hate how they make things like that now so the average guy cant do it him self...thank you for youe help
