jlgp2007nc
All who've successfully top swapped the L26 and ran with the higher compression...Having g problems with pre det and knock all the time? I'm >< that close to throwing it together...
For those that have top swapped L26's, has anyone used a GenIII blower? I know the obvious and easy choice would be the Fiver...but this top swap is basically gonna cost shipping...guessing custom 4 to 3 bolt adapter plate to make it work?
I run a GenIII on an L26 block
But not in an '04+ car
Hence the four bolt TB adapter comment...
Well I have another post up with my list somewhere lol. But
stock block
Gen v with 4.0 and 3.4 pulleys
42.5 inj
1.8 rockers
Intense pushrods
105 springs
HP tuners
LQ4. Maf
And most of the obvious little stuff...
I'm not 100% sure about this, but could you drill and tap your own mounting holes? No adapter necessary if you can do it that way.
Sent from my SkyRocket
