sorry for the long read, i just want to make sure all of the info is out there so i can receive the best help i can.
thanks for reading this, i have what i think is a moderate issue that i hope isnt worse. i have posted this on the monte carlo forums and i am hoping to hear back from others since there may be more users here that have experience with these situations...
[FONT=verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif]swap finished last night, changed settings in pcm to lower timing etc etc etc so it doesnt blow up based on the recommendations that "darkhorizon" suggested here... [/FONT]http://www.grandprixforums.net/showthread.php?t=79466 [FONT=verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif] [/FONT]
car started right up first try and sounded great, idled great, seems like all should be well, BUUUUTTTT......
i am having some issues and any help or advice or first hand knowledge would be greatly appreciated...
here are my swap details....
2002 monte carlo ss
2008 grand prix n/a 3800 bottom end
1999 Buick Ultra L67 top swap
bin file was a stock 2002 Monte Bin that i modified, however, it was not MY oem bin, it was one that i got off the web from a good source.
l67 map is being used, i am sure this makes a difference.
here are the issues that i have noticed.....
scan tool and dash gauge indicate no signal from ECT sensor. it should be working, but it is from the 08 GP, interchange says the 08 GP and 02 monte ECTs are the same. i did swap it out for old ECT from 02 engine. and didnt make a difference, dash gauge does not move at all, and the tuner indicated a -4*C to 0*C, never goes beyond this range.
[FONT=verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif]both fans stayed on when started no matter what with the first ECT sensor, however, after replacing the ECT, they do not come on until i shut the car off. then they run for the allotted time of 1min . [/FONT]
fuel guage is acting wonky, very very wonky. on the first start, it would fluctuate from 1/8th to 3/8th's when ever i would give a little gas, no crazy revving yet. i shut it off for a min to check things over, then restart, and it continues to do this.
so after changing ect sensor out, i started it up, idled fine, no temp change on the dash or on the scanner, and while putting the upper dogbone back on with a ratchet strap, it bumped the throttle and jumped rpms to about 3k for about 5 seconds until i could get into the car to shut it off. i am confident that nothing was damaged. the tune is rich so i dont damage anything.
since then the car doesnt want to start or idle lower than 1200 rpms and it smells very very rich when it does finally start. there does not appear to be any vacuum leaks either. the nipple under the s/c snout goes to map and fuel press reg, the vacuum tree on the s/c goes to brake booster, bbv (which is bypassed and bottom port is open), and to hvac system. vacuum port on side the side behind the TB goes to the evap. so unless i am missing a vac port, all the vac/boost sources are legit.
i have unhook battery and waited then reconnected and it is still having this issue.
case learn and idle relearn hasnt been done.
i have checked all grounds that i can see and remember messing with and all seems well (near coil pack, on trans bellhousing, under intake box). there doesnt appear to be any damaged wires in the harness.
could the ect and fuel issue be some sort of mapping issue with the bin file i used? (powrtuner)
could the 2 bar map be the issue?
any help is greatly appreciated!
2002 monte carlo ss
