Top Swap Pulley Size
xcwilli11
So I'm top swapping, i will be running sd headers, 1.9 rockers, a cai and 1 3/8 on radiator on a gen 3 supercharger. After i let my car get used to the boost what size pulley could i use? (i will be using the stock GTP injectors)
Nobody knows every car is different you need something to measure KR and to make sure your timing is where it needs to be.. If zero knock and good timing then you start to pulley down
You may even wanna start with the 4.0 pulley and check for kr due to the higher compression ratio of the na pistons.
I have a top swapped 06 with a Gen V, stock gtp injectors, 2 bar map, headers, and a zzp gtp pcm and I have 0 kr with a 3.8.
