Found a list of topswap parts....My car is an 04 GP can you guys help me with stuff ive missed and also with stuff on the list i dont need considering i will get a tune ...also what supposrting mods u suggest.
Head Gaskets
Head bolts or arp studs. (arp preferred)
L32/L67 Heads
Rockers
Rocker bolts (reusable preferred)
L32 LIM (suggest plugging coolant ports and opening coolant turn around)
LIM gaskets (metal preferred)
SC tensioner and or coil pack assembly bracket. (depending if your car has one)
SC belt idler stand and pulley (3 bolts)
LIM gasket (suggest metal gasket)
L67/L32 valve covers
VC Gaskets with grommets
Set of coolant elbows (aluminum preferred)
Belt for size pulley
L67/L32 harmonic balancer
L32 DBW TB
L67 or L32 map sensor. L32 would allow you to plug and play with the L26/L36 map sensor connector in your current harness. L67 requires modification of either a converter or new pigtail soldered on.
L32/L67 vacuum line for brake booster
Fuel line swap. (braided preferred)
L32 fuel rails
Head Gaskets
L32/L67 Heads
Rockers
L32 DBW TB
L32 fuel rails
