duane9586
Hi all,
I have a 2005 GP that was a base model that I put in the L32. I have a overkill pcm,SLP cat back,Wizaird,MSD,GEN V,AL 104's,ZZP Shift kit,3.5,Powerlog. I am getting a ton of KR around 4500 rpm's. The car seems to stop gaining rpm's at that point and I can hear what sounds to be the rockers "clattering",poss valve float though I have never heard it so I am not sure. Car has plenty of power up untill that point. I let it shift and then get back into it and its fine until 4500 again then the same thing. Not sure if a bad cat can do this because I hear what sounds to be the crap inside the cat rattling when I give it some gas. Any help would be great. Thank you. BY THE WAY I AM NEW TO TUNING
Here is a scan Attached File 08182009_211002.csv.csv ( 78.8K ) Number of downloads: 1
LONG
QUICK Attached File 08192009_054712.csv.csv ( 18.71K ) Number of downloads: 0
same ones on scandepot
1 08192009_054712.csv from duane9586 -- Scan Depot dot net frames 89-102 KR
2 08182009_211002.csv from duane9586 -- Scan Depot dot net frames 527-539 KR
LONG
