OK, get an extra few bags of popcorn - I got a lot coming. Multiple issues:
1) SES light triggered by ignition issue in cylinder 6. (brother replaced wire and coil) Went for test drive, new scan shows ignition issue in cylinder 1 (and hot cylinder). Tonight will be changing the rest of the coils and wires. I suspected the JY ones might have an issue in the first place;
2) SES light cleared, BUT the following code comes up -
DTC U1064 Loss of Communications with DIM
Refer to Data Link Connector (DLC) Schematics
Circuit Description
The class 2 serial data line communicates information between modules. Each module connected to the etc. etc. etc..........
Long story short, this code is in memory and he was not able to clear this message code.
3) Back to the PCV - The nipple behind the PCV on the SC is plugged. My brother found the plug to be split, so he put a new plug on it. I mentioned that this is supposed to be the clean air source for the PCV (correct???) and ported to the TB. He is a bit dubious and says there is vacuum already at the PCV because he opened the PCV cover and felt vacuum with his thumb, so he's thinking internal port like on a Gen 3, so we have Click and Clack here trying to figure out which is right?
Pictures -
