Throttle position sensor low voltage cody
Hey i just got my car scan and a code for the tps came up and said low circuit. I just purchased a new tps yesterday. How can i fux it because my acceleration and idle was bad on ly way home
Sent from my SM-N920T using Tapatalk
Did the new TPS sensor fix the issue or do you have yet to install the new sensor?
If the problem is still there, you have a power/ground issue to the sensor. You need to check the wiring and any related fuses that deal with the TPS sensor.
The problem is fixed i took it to a shop and they did a reset on the computer its acelerating and idling good now
