Three codes.. what do you think?
NaturallySmashed
p0327 knock sensor 1 circuit low input, p0322 knock sensor 2 circuit low input, p0336 Crankshaft Position Sensor A circuit range performance... I'm guessing I need to replace the cps, what do you think?:th_shakinghead2:
Not so sure about that chief. I'd go to Gearchatter.com and look up those three codes. Bet there's an intersection in one of the diagnostic aid sections for them and it'll tell you about a ground or bad power from the pcm etc.
You got something going on...but I doubt it's just one sensor.
well I can rule out PCM because I have two and it happens with both. The codes do not always come up, but the problem is there because while driving it will randomly jerk/hesitate then the tac will drop to 0 and trac light comes on, it will run fine thereafter.
All I could find from that website is if codes p0327 and p0332 inspect for poor connections at the KS harness jumper. I'm going to double check for bad connections right now.
hopefully someone has had a similar problem that could help me.
okay cool because I couldn't find any bad connections lol i'm not really looking forward to replacing the sensor but hopefully i'll get a chance to this weekend. I'll obviously update this thread after I have replaced the sensor.
of course right now two of the codes went away (the knock sensor codes) and it's running fine lol the problem will return though i'm sure, it's come and gone for a while now.
