FullOutPwr
Ive had an issue with tight turns and having to really give some gas to get the car moving. The abs/ traction light turns on and there is a bit of a clunk then will move.
I looked into it a bit when doing brakes and found the following:
Axles turn freely when the vehicle is tracking straight.
There are no sounds or grinding
Turning to lock in either way the driver side axle does not turn freely when powered by the vehicle. Passenger side is moving fine when turned to lock either way and driver side is the same on lock either way
Ideas?
Ideas?
