Think I possibly need a new supercharger already
Taz Magister
so when I picked up the car paul told me that he thought the squeak was coming from the water pump so I changed it while doing that I discovered the alternator bearing was toast too so I changed that still squeaked so I checked every single pulley the only other one thats ruff at all is the idler for the sc so I'm going to change that today but I'm starting to wonder if the sound might be coming from the snout or something... which would suck I might be wrong and I'll find out when I change the idler but any good ways of telling if the snout bearing is bad? also I'm new to the whole sc thing and I know they get warm but the other day I drove my car a bit parked it in the garage for like 30mins maybe a little more came back and felt the top of that thing and it was still pretty dang warm how hot do they get?
its called a heaton for a reason.
They can stay warm for 5-8 hours after they get completey warmed up.
Just because the snout bearings may be bad doesnt mean you need a whole blower, just buy a different snout and swap them and call it good. Thats what I had to do.
well I would like to swap the rotors out as well its an old blower I see that you can buy bearings for them anybody changed them before?
Fransworth is one of the only guys around that I know of that does it. Its not easy to do and requires some special tools I believe.
And putting in newer rotors that may have more coating on them most likely wont net you much if anything.
I have 286k on my stock SC and the bearing are still fine. Not saying they don't go bad, but not something that is typical.
A bad idler is much, much more typical. I would change every idler with the metal ones.
so after replaceing all the pulleys I discover its the belt.... this happend last time I got my car back from paul lol wtf is he doing to my belts this belt is basicly new Id rather not replace it but I might
also you dont want to swap a rotor pack into a diff SC case. they wear together and you will mostlikely end up with a leak and loose boost.
What belt are you running now? Size and brand.
Did you cover the needle bearing with tape or something when you ported it out? My belt sometimes skips one rib over on the crank pulley and it makes a weird noise but it only does it every once in a while.
I did and I put some extra grease on there when I put it back together it might not be them the sound went away there's some slop in the rotors tho
Needle bearings in a SC case aren't bad at all.
Here's what you need
here's how you do it.
1. Remove charger and flip it over. Locate the two holes here that are filled with red
2. Drill them as straight as possible, do not drill into the bearing cap. Drill in steps if needed to keep from puncturing the cap.
3. Tap the holes and assemble the npt pipe and coupler to your grease gun
4. Pump grease gun to hydraulically push out the bearings.
5. Insert new bearings and tap into place (I like to find a socket that fits the outside and use an extension to tap them if a press isn't available.
OR
Get a blind pilot bearing puller and pull them from inside the case.
