Thermostat.
Bad thermostat can reduce he amount of heat you get. What does the temp gauge say its running at? Near the middle or more towards the bottom??
Could also be time for a heater core flush and coolant flush with a new thermostat.
Gage stays in the middle. Had heat this morning. Didn't last night. I'm thinking coolant needs to be changed too.
Sent from my EVO using Tapatalk 2
when was the last time you had the coolant system serviced?
maybe time for new stuff...thermostat,coolant,bleeding system of air...could be the 100% solution
that would be the simplest
