Thermostat Questions
mycutlassblue
Hey you all I have a question.. Does anyone know what a stock 98 gtp's thermostat should run at?
My car never seems to hit 200 always runs below the first line.
My dad is a mechanic and has told me that It should be running a little hotter and that I could quite possibly get a little better gas mileage?
I'm guessing someone must have put the cooler thermostat in this car at one time.
Has anyone noticed gas mileage difference by adding a cooler one?
Any performance changes between a hotter and cooler one?
I like the way my car runs, but it does suck gas. Also my owners manual says they have an 18 gallon tank.. I have only been able to put in 12 gallons on the E mark.
Use a scan tool to see what the temperature sensor is actually reading...you are probably operating properly at ~200°F. A lot of the temperature gauges read low.
yes, my MPGs noticeably went down when i switched to a 180, nothing major, but i did notice it. i felt absolutely no change in performance.
Because you're not boosted nor have ported heads and a cam.:th_thumbsup-wink:
Colder T-stat is a KR killer. Not the best one, but not a terrible one either. If you're not knocking, it won't help.
Well I had a T-Stat that was stuck open and keeping the temperature of my car below 160* (IIRC). My gas mileage was horrible... I hated it. I thought this was the price to pay for a supercharged car. I replaced the T-Stat with a new 195* failsafe T-Stat and I could really tell the difference between the gas mileage. It got a lot better to my surprise! No performance gains though... at least not that I noticed.
Because you weren't knocking :)
Also why would you bother with a failsafe? For a dollar or so more you can get one with a lifetime warranty.
oh, well that's good to hear that I'm not knocking.. Because I don't have a way to scan.. and don't feel like dropping $200+ on an aeroforce gauge.. even though I'm convincing myself it's worth it lol.
And because my Autozone had a normal one for $8 and a failsafe for $11.. and that was it lol. So I got failsafe. I think it has a warranty on it.. but I forgot how long. And I was just looking at that little thermostat and wondering.. people actually drill those? Where? and for what? To get constant cooling to the engine?
the 'failsafe' is a hole drilled into it so it cant ever close completely, even if it fails closed. you could have done that for free by yourself with a drill.
guess ill post my question here since its already being talked about... getting ready for 3.4 setup... if i get a 180 t stat will it benefit me at all?... seeing as how i dont have fans set to be turned on at 180.
i should be alright with 195* t stat, 104's, headers for 3.4 until i get retuned? i had my tune flashed last year sometime and never got it retuned. always run 93 octane.
