The *Unofficial* GPF RC Thread
Took the Ruckus to the bmx track today, did a huge jump and landed in a grassy area then cartwheeled a few times, then landed back on the wheels and I noticed one of the wheels wasn't turning. I must have looked for that steering link for 30 min it was nowhere to be found.
Then in the process of making a makeshift steering link I snapped off part of the steering bellcrank :(
Looks like its time to clean my shocks again too.
He doesn't want to spend more than $100, I have not found a good 1/10 rc for under $100. They have a few 1/12 scale.
I told him not to make the same mistakes I did and just buy a real 1/10 or larger brushless.
He could get one of these, but it is worse quality than the WLToys http://www.nitrorcx.com/16c332-red-rtr-24g.html
Actually that one I linked on Nitrorcx is a decent one, I was thinking of the 1/8 scale Iron Track vehicles. Jared look into that Iron Track Tanto. I would recommend getting lipos and getting a lipo charger.
I bought a 2.5 T-Maxx a little bit ago, pretty fun little thing and fast too.
Flipped it a few times now and body is dinged a little but it's all part of the game. I just clean with my mini air compressor after every use to prevent build up and stuff. Tuning is a challenge for sure because of temp swings but it's not all bad and it's quick to dial in. Ran nearly 2 quarts through it already and I need more fuel, just going to buy a gallon this time.
The tank is 125CC and it doesnt last but 10-15min if you are bombing it. Plus to run on a safe side and not blow it up, I do run it slightly rich and traxxas says thats okay per the manual. It still hits 2nd gear and flys thats for sure.
The little fuel filler dealio holds 500cc of fuel and thats gone in under an hour of drive time.
i always bought gallons. one thing about the t maxx. no need to worry about tagging a curb, it just goes over it at any angle it seems.
you can pick up a laser temp gun to check the temp of the head. best way to know if your lean. other then no smoke out the tail pipes lol
Yeah running up a curb at 30+ is easy but kinda scary at the same time, the suspension travels so much that sometimes it makes it unstable and it can get squirrelly on you.
I used my temp gun during break in and now I don't bother. Going by the smoke is easy now and it's always running at 210-240 whenever I do check.
Also, I need to take up stock in glow plugs I guess. I bought 3 extra from ebay and in 1 day I had two burn up like right away, so now I only have 1 extra.
all glow plugs are not created equal thats for damn sure. cheap ones dont last long, but the traxxas ones seem to last the longest. iirc years ago they were 8 bucks a pop, the cheap ones were like 4 or 5.
the break in deal will kill that first glow plug.
i used to get a gallon fuel easy out of a glow plug, if not more. you do have a larger engine then i did. you got the 3.3 iirc? i had the older 12 and a few up graded OS 15's cause you learn to have a spare engine in the tool box lol
you got the hand held battery pack set up right? idk if those are bad or not for the plug. mine was a pull start and you could have the plug igniter on there for a pretty damn long time sometimes.
plug in hand you can pop it in the old plug igniters and see the coil glow, if bad they failed to glow or glowed dimly, and the coil would be miss shaped as well.
Replaced my front A Arms with RPMs.
Got a Robinson Racing 22t pinion and a Hot Racing 85t Metal Spur.
Replaced the seals in my leaky shocks.
And got my slipper set a tad too tight and ended up breaking an axle.
Replaced the axles with Traxxas VXL shafts. Think I might get a set of MIPs.
