The FWD Cobra: Just one more thing then the MG gets all the attention
Re: The FWD Cobra
3 of the wheels are painted the 4th is prepped. I just have to wait on a new tire to get delivered amd mounted. So these won't be on for about a week.
Here's how they came out plastidipped:
Re: The FWD Cobra
Decided to do a test fit on one side since I was bored.
Front offset:
Rear offset:
Car shot:
I'm going to get some spacers since I can barely put the centercap on because of the axle stud. I'm thinking something like a 1/4"-5/16" should work. The suspension has to settle A LOT, I could get 4 fingers in the rear gap lol. The tires are ~.4" shorter than stock.
Re: The FWD Cobra
those look great, im happy this all worked out for you man. i do agree ont the spacers and tires but for now its looking good... is that a butt load of camber on the rear or am i just seeing things?
Re: The FWD Cobra
If the tires were a 45 sidewall then it'd be the same as stock, after the suspension settles it'll be much better. As for the camber that's just where the suspension is, I don't have any sort of adjustment in the camber.
Re: The FWD Cobra
After doing the test fit I realized how ****ty my brakes and suspension looked. Now I want to paint the calipers. Black or silver, which one should I do?
Re: The FWD Cobra
Silver calipers and black brackets...or vice versa...contrast is where it's at.
Also.
holy zomg tiny brakes...you need at least a 12" upgrade or some FBody's!
Re: The FWD Cobra
Also.
Black is the only color that the store had, so maybe silver calipers down the road, and the brakes will definitely get upgraded in the near future. I'll really clean the suspension since everything is filthy.
I also found out while painting the last wheel that the sizes are actually 18x7.5 +45 and 18x9 +40. I wondered why a couple of the tires looked stretched lol.
Re: The FWD Cobra
if he did the 11mms hed be at 36 offset.. i cant tell.
whatcha do bro? whatever it was it looks real good. i thought it was going to be flush-er though
Re: The FWD Cobra
The 9s are up front and the 7.5s are in the back with a 5/16s spacer which is ~8mm, so they have about +37. None of the local stores had 7/16 spacers unfortunately.
Edit:
The fronts are about where I like them. As for the backs I'd like for them to be a little further out so I may look into longer studs and thicker spacers.
