the codes my car is throwin
cliffdawg
alright kids my ses light turned off the other day finally up to 440 miles on the rebuilt engine but had a gut feelin i should scan it so i went to auto zone got the scanner and it came up with these with the ses light still off
p1361 not to sure what that is but i also go p0107 which im pretty sure is the vacuum leak correct anyways ya
Really, is it hard to look up the codes and post what they are? ignition control circuit low voltage Sounds like a kinked wire P0107 trouble code which refers to Manifold Absolute Pressure/Barometric Pressure Circuit Low Input Id say theres a harness issue as im pretty sure there bundled together. Non of those are indictive of a vacuum leak. Check the Harness
no my pen wasnt workin so i just wrote what the numbers were but the car every once in awhile has rough idle and dies at idle so i was thinkin vacuum leak of some sort
now when it came up with the p0107 it said misfire and i do know this for a fact that im getting gas mixed with in the oil because my rings havent set
My car is throwing a P0107 code and it indicates either MAF vacuum leak or 22 sensor...not sure which one it is, but never said anything about an manifold absolute pressure. What that about and would it mess with the rpms @idle?
