Testing Wires?
apierce1289
Okay so my car was throwing codes for the intake air temperature sensor. I replaced the intake air temperature sensor with a new duralast 1. I'm still getting the same code p0112 and i cant figure out how to test the wire and fix it. Help
Well for power could use a power probe which you just touch the wire and if the light bulb lights up you have power there or you could use a multimeter. with the multimeter you can see how much power is there and you can also test if it is an open or closed circuit when using Ohms. Hope this helped.
