T
TDCRacing
Guest
I'm not good with relays...but im sure we can figure out something with a cupple relays and a switched ingition source maybe if we can't figure out anything else.
Here's your wiring diagram for the cooling fans.
Don't count on it. I've had this problem for I think about seven months now. I tried everything people suggested with no results, and eventually people just stopped replying. Both in the forums and in PMs.Frustrated big time. I'm sure somebody had this same issue and will help us out.
when you did the intake gasket did you notice if the coolant holes were plugged and was the coolant used dex cool? I've read that air interacts with it and make sludge build up in your system. I have an 06 with only 43,000 and mine started to give wierd temp signes. Looked at my rad cap and damn 1/2 inch of sludge was on the bottom of it. Did a good flush used a super cleaner and fiiled up with non dex-cool and so far all is good.
