Hey timboku, I apologize I didn't get the chance to respond. Thank you very much for that info, it has helped me a GREAT deal. Anyhow, I decided about a week ago to go ahead and attempt this with my father. He's sort of hard headed and didn't want to listen to the proper way of doing it, and wouldn't let me really help at all. So he ended up removing ac lines, removing the linkage, bending AC lines out of the, and breaking off the TCC solenoid inside the transmission. He eventually got it out but if I'm correct you should lube them up with tranny fluid before reinserting, correct?... or it's at least a good idea. I know he didn't lube it and has to pound it in. He refused to drop the cradle... seeing no reason for it. So after 2 days it was all back together and running. I notice a difference right away. It seemed to have more power but at the same time it was slipping worse than it ever had. I went from one check engine code to NINE. Transmission over temp, gear ratio incorrect, 3-4 shift solenoid, some sort of AC code, lol. So here I am now, I bought the EPC solenoid, both shift solenoids, and the manifold pressure switch, plus I bought another TCC solenoid just to be safe. I asked my father to help me again but he believes the engine will have to be pulled to do it. So it's sitting in my back yard about halfway done. I've got all bolts removed except, the four T 40 star heads on the bottom, I can't seem to get them out. I tried using an impact gun but it will not budge them, I tried using just a regular ratchet and it rounded out 2 of them, I soaked them in PB blaster for a good while first. I'm trying to think of some sort of solution. Any help would be great thanks.
