Really isn't nothing to be afraid of...
This is the almost completed result (test fitted sensor), just be patient.
Take down big chunks at first if you can, I used a drill press, lol, to take a majority of the material off. Then went slow as you near the end. A bench vise to hold the TB works well for the grinding. I also used a bit extension, with a small piece of EMT electrical tubing (1/2") as a sleeve to hold the bit extension loosely and allow it to rotate while grinding and apply pressure easily.
Don't worry, as Reptile mentioned, you will bore holes through the casing on the TB. Just rebuild it back up, I used the JB Weld Stick which is easy stuff to use. It's rated for 500*F so no worries there too. Make sure the surface you're putting the JB weld onto is all cleaned up nicely though, just as a precaution.
You cut off a chuck of the stick and roll the bead between your fingers. Then with a little water while mixing it up (just wet fingers and continue to mix it between fingers) and this made it real pliable and allowed easy shaping. It will set up fast as time elapses but no worries, there's plenty of time to work the material, say 5-10 mins. Allow it to dry for a while but not all the way, say about an hour, then I took some material off again as the JB weld is not fully set and easy to remove, but left it high enough to final grind/sand. Be careful here as it's easy to take too much off and you'll have to re-mix and apply the JB weld again.
Then the final grind and sanding was accomplished with a dremel using the flexible extension.
Added bonus... Paint job! lol...
