It's running smooth and fine as can be. Sometime (maybe once a month) if I'm sitting in traffic for a while with the a/c on full blast and just give it enough gas to move forward 6 feet it will almost stall, then the rpm's will shoot way up to 3k and then it goes back to normal. Other than that it runs perfect.
idle air control valve,, take it out and clean it or replace it
have you checked your fuel trims and also see if it goes into closed loop?
Dont I need a scanner for that?
