Tachometer goes to 0 while driving
I had the same issue replaced the sensor, still had the problem icm was the faulty part but it is a difficult call between the two. However icm is much easier to replace
i checked ICM last fall, My car did a wierd thing it made the shudder feeling and tach went to 0 and stalled and then started back up and ran ok does it sound like the crank shaft position sensor to you guys
Autozone/Advance Auto/non OEM ignition components (ex. Crank/cam sensors, icms). = I highly advise against. Just from past experience.. Not saying they are all bad but have a much higher failure rate/incorrect specifications. Just a heads up.
Sent using my Galaxy SIII on Tapatalk 2
Yep I know but was in a hurry only reason I used duralast both times is second time It ws covered under warrenty it happens again I go with MSD
