T67 rebuild kit
if you have it off the car look for a stamping or engraving on the outlet of the turbine housing or the outlet of the compressor housing. IIRC its basically a PT-6776e turbo. im sure DarkHorizon will be along shortly to correct me if thats not right.
Any T3/T4 rebuild kit will do the job.....just make sure that it comes with the upgraded step gap oil piston ring (rear oil seal) and 360 degree thrust washer.
Took off my boost pipe and its covered in oil so its the cold side and maybe the hot side too. Should I send it in to someone or is this a rebuild I can handle? Havent checked for shaft play yet....
