T-unit's boosted Buick AKA the Granny Slapper
This is right under the floor board area. I'll just get all new steel lines. Inline tube is semi local and has all sorts of stuff. Pre bent and ready to go. I'm just gonna go that route since every line is trashed.
Sent from my XT1635-01
Tyler/T-Unit
Turns out nobody makes pre bent lines. So I'll have to remove them and send them to classic tube. They'll make custom stainless lines for it. And the prices are decent as well.
Tyler/T-Unit
Not true....Look HERE on the Classic Tube site. They make pre-bent stainless fuel and return lines for all W bodies and also have pre-bent brake lines for some models as well. If your fuel lines are gone yoiur brake lines are probably right behind them so I would look at doing all. My fuel lines are looking terrible, so they will be next.
I just ordered a set of pre-bent stainless brake lines from SS Tubes, both rear lines were $100 shipped. Issue I had with them was that they needed to be cut and re-flared for the rear proportioning valves...which was why Classic Tube said they didn't make lines for my '02.....but I have the flaring tool so no issues.
i just got brake lines off ebay, pre bent ss lines, and fuel lines from lines to go.
I've searched and didn't come up with anything.
Will those work with supercharged versions? I've never gotten into the fuel lines beyond the quick connect fittings to see where everything goes or how it ties into the lines under the car. They're always loomed.
I remember calling them now and the guy said its for the naturally aspirated cars.
I already have one brake line done. I need one more.
Tyler/T-Unit
I just went through brake lines on the truck. I did every hard line in stainless and every rubber line in braided stainless.
Tyler/T-Unit
I ordered a set of pre-bent stainless brake and fuel lines from Classic for my 01 Suburban a few years back...same as you, but cost me over $1500...the 8.1L burb has 2 fuel tanks each with its own pump and evap/return lines. Brake lines were easy LOL.
I dunno if the SC and the NA have different fuel line configurations, I've owned both and they look the same, but I'm not the expert here. You may want to call Classic and ask. Rock Auto has this FineLine fuel line set for my '02 for $116.79, which I think is made by SS tubes. You don't say what year your Regal is.
http://www.ebay.com/itm/322519017745?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT 97-98 are year specific, but this same seller has other lines for the newer regals as well. hes got SS lines, what i got or normal metal lines that will rust up down the road on ya, SS lines were line 35 bucks more, so i splurged on em lol
fuel lines i was not able to find on ebay, but i got them at "lines to go." https://www.linestogo.com/buick-reg...NtXqsqeWHzQvaGWnbwRpLMagPG39ODDZHZxoCp7Lw_wcB
once again these are 97-98 only fuel lines. even has the evap line. but they got other years for these as well.
I had to get two sets of lines for my 97 Chevy. The first was a set of SS tubes from fine lines off eBay. The other set was from inline tube off eBay. I got rid of my ABS module on the truck so I had to do some digging and after getting most of the 95+ lines on I realized the setup I was running was identical to the 94 back years so I got the inline tube set.
I could have sworn I put my year in this thread somewhere. It's a 2000 regal GS.
I need lines for a 2000
Tyler/T-Unit
