T-Fitting for my vacuum line & boost gauge.
DnaProdigy
I have been attempting to locate a rubber t fitting for the vacuum line. I need one to replace the cracked one on the passenger side just under the S/C snout and another to run a boost gauge (behind the blower near the map sensor.)
Does anyone know where i can find this rubber t fitting? Or better yet if i can get them from GM is there a GM part number?
I have found plastic ones in the Autoparts stores but they were either too big or too small. The closest one fit the hose but the lip, like 1/8 of an inch down on the hose, did not fit thus making the fitting too small.
Any help is appreciated!
You can make your own T-Fittings by purchasing the 1/8" plastic vac line t's from your autoparts store. Use some rubber tubing.. to connect the 1/8" lines to the T.
