Adidasdude1989
What do you guys think? Right now i have 2 mtx audio 12s with a 1500 watt American Bass amp, 1 sub blew because i cranked my bass boost all the way up...oops
Opinions wanted:th_thumb-up::th_thumb-up::th_thumb-up:
2 of these 15's
Im getting all this with enclosures for $470, regular price $670 but giving back my 1500 watt amp for $200 which i paid for originally from the guy.
- 1 Ohm Stable Class D Mono Block Amplifier
- Low Level Input and Output
- Frequency Response: 15Hz ~ 270Hz
- Input Level: 6V ~ 0.2V
- Variable Subsonic: 10Hz ~ 50Hz
- Variable Low Pass Filter: 35Hz ~ 250Hz
- Variable Bass Boost: 0 ~ 9db
- S/N Ratio: >85
- THD: 0.1%
- Remote Gain Controller
- Two Amplifiers Linkable Connector and Selector
- Fuse Rating: 120 Amps, Linked Fuse Rating: 240 Amps
- 3500 Watts Max
- 1600 Watts RMS
- Dimensions (Inches)
- Height: 2.18
- Width: 9.13
- Lemgth: 16.53
2 of these 15's
- Impedence (Ohm) 4
- Rdc (Ohm) 3.5
- Levc mH 3.783
- Fo Hz 30.4
- Sd msqM 76.45
- BL TM 16.295
- Qms 4.764
- Qms 4.764
- Qes 0.635
- Qts 0.56
- n% 0.375
- SPL dB 89.8
- Vas L 89.6
- Cms uM/N 105.6
- Mms g 259.6
- VC Inch 2.5
- Mgnt oz 120
- Xmax ±MM 15
- RMS 500W
- MAX 1000W
- F.Range Hz <500
- Mounting Depth
- MM 228
- Inch 9
- SPK DISP. L 6.824
